Originally Posted by Boxtaboy
It looks like you need to first take the entire rivet out first, and put in new ones. In your picture, you pulled the pins out, but the rivet base is still inserted in the wheel liner. when you insert the new rivets (I always buy new ones whenever I take the wheel liners out because you always ruin a few when removing), assemble them correctly first before putting in (ie. put the two pieces together with the pin halfway in the base), then push the rivet in place. Once the rivet is in place, secure the rivet by kust pushing down until the pin is in the rivet.
I did remove the whole entire rivet assembly. I wasn't able to get then back in like they came out,in one piece. I just inserted the pieces like that for now because it's a tighter fit then nothing in those spots at all.
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
