Old 03-28-2025, 01:50 AM   #2
dennisleonardok
Originally Posted by 997_986 View Post
I don't know if it couldn't be solved quite simply by replacing the old with a new relay, because as long as your control expects the switches, you have to supply them. A new relay would probably not have all that. But this is only a suggestion and a very long shot ...
The relais from MY 00 onwards is 986 618 199 00 and sits above the fusebox ...
Yes thanks, but this wont fix the issue with the B-Pillar microswitch
dennisleonardok is offline   Reply With Quote
