Old 03-26-2025, 03:17 AM   #9
professorman
Originally Posted by N227RV View Post
No, I'm the OP and don't have the bit identified yet. I suppose the Harbor Freight set isn't all the expensive, so I'll probably buy the 100-bit set and see which one, if any, works. The car is 21 years old.
That kit is nice to have, it has lots of security bits that I haven’t seen before. It is the security T20, with the hole in the middle. It’s the only one that I have seen on this car though.
It also has the triple square M8 that you need for the door lock. That is a a common failure point on Boxsters of this generation. I guess I rounded that triple square in the past because it was missing from this set. I bought a nice triple square socket set from Amazon. I had to take off my door lock 4 times in the past month as I troubleshoot and failed to repair my door lock several times. It’s finally fixed now tho.
If you wrench on your own car, it’s nice to have the right tools when you need them.
I have cleaned my MAF twice in the past 2 years, but I finally accepted that mine is bad and replaced it last week.
professorman is online now   Reply With Quote
