Old 03-24-2025, 11:30 AM   #1
professorman
Originally Posted by elgyqc View Post
The first front engine mount I changed didn't have have these stops so I made my own like this.
https://986forum.com/forums/performance-technical-chat/79456-diy-engine-mount-stop-9a137525701.html
Perhaps a shoe repair shop would have a thinner but robust material that could be used.
In your update, you said you DIY mount stops might have contributed to vibrations due to the thickness.
Your posts list your car as: 2000 base.
You list part # to be: 9A137525701 - $31.89 each On FCP Euro site, however, that part number shows compatibility with only 2005+ boxster
The part number that come up for my car (2001 986S) is 98637525501 which is a lot thinner, and cost $14.19 ea.
Is there a reason why you did the comparison with the newer part number?
I intend to just buy them, so trying to find out if I should go with the newer design or the correct older design.
01 Boxster S 6Spd, Speed Yellow w/84k miles. | 991.1 911 C2 7spd Manual | 01 996 C2 -6spd - Green Machine - My baby | 997.2 C2S 6spd | 2x 01 Boxster base
professorman is offline   Reply With Quote
