Old 03-20-2025, 06:30 PM   #1
Gilles
Mark, I have a picture of the 'smart strings kit' and you should be able to replicate fairly easy. The settings are very simple, but you have to be accurate, specially when setting the fishing line distance between the fishing line and to the center of the axle, as you need the "exact" distance to the hub center (front and rear axles), this creates a true square of the car and then, you 'simply' meassure the distance between the front of the wheel and rear, determining toe.
For a complete alignment, you will need something to meassure the camber (can't remember what is called)
Gilles is offline   Reply With Quote
