Old 03-18-2025, 04:42 PM   #393
LoneWolfGal
LoneWolfGal's Avatar
I'm back from the world of inspections, preliminary reports, seller disclosures, vesting deeds, septic and well-water test results, etc., etc., and the inevitable so forth. Now I need to get cracking on that engine, get it all ready to stick in the car. The OEM cam chain wear pads (a.k.a. timing chain guide rail sets for VarioCam solenoid-actuated chain adjusters) and assorted seals and gaskets I ordered from Pelican on 3/7 hadn't arrived yet, so I called them to see what the holdup was. Turned out they had the wrong billing address associated with my debit card, which seems strange, given that I've ordered lots of stuff from them with the same card. I gave them the correct billing address, the card went though, and they said they would ship the order out today. No harm, no foul, since I won't be ready for those parts until next week. It's too late today to run that socket over to the machine shop and have them drill it out to 3/8". I've broken or worn out three drill bits so far, but I have more bits left, so I might give it another try tonight. Once the screwdriver can fit through it I can finally torque the IMS stud nut. I also picked up a couple of sheetrock screws, which Jake Raby claims is just the ticket (together with pliers) for removing the old rear main seal. The new seal and installation tool for setting the seal's depth are ready to go.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
LoneWolfGal is offline   Reply With Quote
