Old 03-13-2025, 01:39 PM   #16
Marc_986
Thanks! Got the holes to align today. It was fairly easy with two people, one pulling a little bit while to other drops the bolt in. Seems to fit without issue, so giving some confidence in this car.
Measure the ride height as well today,
The front seems a bit low at 12.7mm but the tires look a bit low on pressure. So I guess it will pop back up to the correct height for M030 ROW.
The rear sits a bit on the high side, more or less at spec for normal ride height. So either it will need to sag a bit or the car doesn't have the weight yet. No big issue anyway.
Next step to do a coarse rear alignment.
Marc_986 is offline   Reply With Quote
