Old 03-01-2025, 11:31 PM   #382
LoneWolfGal
LoneWolfGal's Avatar
You need what is call a "pass thru socket" set:
https://m.media-amazon.com/images/I/91kvbpIVoDL._AC_SL1500_.jpg
The sockets have a large thru opening that the screw driver can pass thru and uses a special rachet that grips the flats on the outside of the butt end of the socket:
Now that you mention it, I would actually love to have a set of those. However, I'd be surprised if the set's 7/16" socket has a small enough outside diameter to fit in the notch and on the nut, since few do. You've installed a number of Solutions and you must be aware of the flange notch's small size, making access to the nut difficult with standard tools, so what do you use to tighten the center stud's nut?
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
LoneWolfGal is offline   Reply With Quote
