Old 03-01-2025, 03:41 PM   #378
piper6909
piper6909's Avatar
Originally Posted by LoneWolfGal View Post
True, but you would still need a way to tighten the nut on the stud. The 1/4"-drive deep socket would also need modification to fit a larger screwdriver through it, but that socket belongs to LN's rental kit. I'm working on the 3/8"-drive socket now. I was overly optimistic in predicting the tungsten-carbide drum would grind it down to size "in short order." The steel is tough, so it's taking more time than I had figured on. But I'm making progress.
You can use a set of vice-grips on the socket. You only need to tighten it enough so it doesn't spin when you put a torque wrench on it, right?
2010 Subaru Forester
piper6909 is online now   Reply With Quote
