Old 03-01-2025, 10:25 AM   #7
LoneWolfGal
LoneWolfGal's Avatar
Have you thought about griding off these edges of the screwdriver, or a similar throw-away screwdriver? Looks like you can reduce it by about 2mm on each side.
True, but you would still need a way to tighten the nut on the stud. The 1/4"-drive deep socket would also need modification to fit a larger screwdriver through it, but that socket belongs to LN's rental kit. I'm working on the 3/8"-drive socket now. I was overly optimistic in predicting the tungsten-carbide drum would grind it down to size "in short order." The steel is tough, so it's taking more time than I had figured on. But I'm making progress.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
LoneWolfGal is online now   Reply With Quote
