Old 02-23-2025, 08:52 AM   #16
piper6909
piper6909's Avatar
Originally Posted by LoneWolfGal View Post
Thanks, you guys. I already tried the socket/screwdriver method yesterday, but I can't seem to get the nut tight enough so that the stud doesn't turn. It needs to be fairly tight before it can be torqued. I'm going to try again, turning the socket with vice grips, protecting it with a shop rag. The problem is that only a small screwdriver will fit through the socket, seemingly too small to hold the stud. Nevertheless, after working on it all night in my dreams, I'm going to have another go at it. The hopefully thinner-walled box ends won't be here until later today anyway.
Were you using a 7/16 with a 1/4" drive or 3/8"? You'd fit a larger screwdriver if you have one with a 3/8" drive. And the passthru sockets from Harbor Freight have an even larger opening.
Hopefully I'm wrong, but I suspect the thinner box wrenches may not me much help in this situation.
