Old 02-23-2025, 04:07 AM   #353
piper6909
piper6909's Avatar
Originally Posted by LoneWolfGal View Post
Been looking at wrenches on Amazon. Most of them look like mine. I added "thin-wall" to the search and it came up with this set:
https://www.amazon.com/HORUSDY-11-Piece-Wrench-Combination-Organizer/dp/B0C9W2C34M/
More cheap Chinese tools, but I figure for what they cost, if the set's 7/16" box end works on that one nut, I will consider it money well spent; otherwise, I'm out only fourteen bucks. To my eye, these 12-pt box ends do look perhaps a millimeter thinner than on the ones I have. They'll be here tomorrow and then we'll see.
Why, you may be asking, does LN use both metric and SAE? That's a good question. The oil-line fittings are metric, but the Solution Supplemental kit provided a 7/16" deep socket specifically for that one nut, which came in the bearing kit for the stud. Wish they had included a 7/16" box end that I could get on that nut.
Perhaps you'd be better off with one of these pass-through sockets:
https://www.harborfreight.com/sae-and-metric-pass-thru-socket-set-21-piece-62305.html?utm_source=google&utm_medium=cpc&utm_campaign=21901739207&campaignid=21901739207&utm_content=171677809102&adsetid=171677809102&product=62305&store=496&gad_source=1&gclid=Cj0KCQiAq-u9BhCjARIsANLj-s2nkJNBm1KzUzJU4wwXF8mwDPMCKJ1H48bAjB74_eW5FNLna8e AnpgaAi3_EALw_wcB
Your problem seems to be more of a depth issue than a clearence issue. These are sockets that are open all the way through so you can use a screwdriver to hold the bolt. At the same time, like every other socket, they can reach in and tighten the nut.
