Old 02-16-2025, 02:09 PM   #1
gbp808
basic BRAKE question please.....
Hi All,
box-s 2001, new to me, acquired as a roller, pleased (very!) to report that she is running after immobilizer replacement, and the rest ended up being cracked plastic tubing (so far, that is), fuel pump and sender plastics, vacuum hoses etc,
Did not notice on around-the-block test drives, but today it is clear that there is little-to-no stopping power. Even coasting to a stop sign, i have to "stand" on the pedal. Not spongy, small amount of pedal travel, no noises, no locking. I lifted the e-brake on one of these coasts and it seemed very weak (added this in case it helps)
I believe it is ABS 5.3 based on blogs and part # 986.355.755.00 in the vehicle.
Since I never drove this Box in her prior functional state (nor any other porsche actually), I am assuming that this is not right. It feels exactly like when my manual tacoma is not running and I let it roll down an incline a few feet and then try stop it with the foot brake, i have to push really hard. So it seems as if the boxster has no brake assist at all. I honestly cannot recall if the brake was working more normally on the short tests, and this is a new problem, or if it has been like this since she fired up 2 weeks ago (so focused on noises, codes etc and driving slow)
I have no ABS codes on Durametric, fluid is full and looks clean.
No crack/perish/brittle with the large bore hose from the booster, no water signs.
Wondering if anyone has had this issue, before I start a deep dive.
Thank you in advance!
gbp808 is offline   Reply With Quote
