Old 02-15-2025, 03:10 PM   #1
BoxsterInTheSun
Originally Posted by Burg Boxster View Post
If you have an AGM battery, there will NOT be any vent ports so you do not need to worry about that tube. Most owners w AGMs typically zip tie the tube unto itself or out of the way. Then it's not just flopping around or interfering w/ battery install/removal which is a cumbersome enough task.
PS - Hard to tell, but looks like your battery tray could use some loving... if it's overspray, or dirt fine. If it's previously spilled battery acid corrosion, hit w some baking soda/water to neutralize. Then a quick sanding and rattle can repaint (outside of vehicle of course) will make it look spotless again. Nothing tougher than trying to diagnose issues when previous stains/leaks/etc. are prevalent.
Good luck
Looks like I have an AGM battery so I'll just zip tie it out of the way! Thank you!
BoxsterInTheSun is online now   Reply With Quote
