Old 02-10-2025, 02:32 PM   #313
JFP in PA
Generally, if there's high speed and/or high load its called a bearing. Think main and rod bearings. They are really bushings, but given their application they're called bearings. The same would apply to the solution.
Think of the small end of the connecting rod on an old style V8 engine: to allow the piston wrist pin to properly float, the small end of the connecting rod has a bronze sleeve bushing pressed into it with annular oil groves in it to permit lubrication; when in operation, that sleeve becomes an bearing.
What it is is all a matter of semantics: a mechanical engineer would call the Solution a bushing because of its design features; in function, it is an oil fed bearing.
