Old 02-10-2025, 02:05 PM   #6
Gilles
Originally Posted by GeorgeP View Post
Boxster 2002 - code P0455
I checked all the lines and didn’t find any leak. The only sign of leak is at the top of the tank / sender.
There’s a strong smell of gas in the cabin. I replaced the sender’s gasket, but the smell of gas persists. I noticed that the connectors show signs of leak. Do you think is worth to replace the connectors or I need to replace the sender?
Please look at the pic before I replaced the gasket.
George, one day my wife's Volvo S60 started to have very strong fuel smell inside the cabin (the fuel tank is underneath the rear seat), and after removing the entire float assembly, I noticed a hairline crack on the white molded plastic piece (the main piece that holds the connectors and the breathing hose on your picture) After I replace that piece the smell went away.
Please note that on the Volvo, fuel tank there are two inspectiond covers, one at each side of the tank, one for the fuel pump and the other one for the float assembly, but I believe that on the Posche, that white plastic is the base for the fuel pump and float assembly, therefore you may have to install a new fuel pump assembly.. Good luck!
