Old 02-05-2025, 09:03 PM   #10
LoneWolfGal
LoneWolfGal's Avatar
Since the bearing I'll be removing is a factory dual-row job, it doesn't have an external snap ring. It has an inaccessible wire lock and I hear tell it requires considerable force by the puller to break it. When it happens it's like a gunshot, they say. And the bearing will likely leave behind wire-lock remnants that'll need to be cleaned out, a job for my telescoping magnet. Hey, I'm looking forward to this episode.
After I get the bearing out and the opening sealed, I need to elevate the engine and slip two 2x8s under the sump cover, which will provide the clearance necessary to get my right-angle grinder under the bell housing. Most of grinding will be done from underneath, like in Raby's PCA video. It affords the clearest view of the cutout's outline as I'm working. I plan to take photos of the entire process — at the risk of documenting "... and here's where everything turned to **bleep**." But risk comes with the territory and I'm not a scaredy cat.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
LoneWolfGal is offline   Reply With Quote
