Old 02-03-2025, 10:07 AM   #1
BoxsterInTheSun
i think also for cruise control - cruise disengages on clutch depression, yes? do you have cruise, and does it randomly drop out on you? perhaps initially just check the plug at the switch and hit it with some contact cleaner.
I have this exact same issue with my 2002 base model 986, it bogs down slightly after changing gear and starting to accelerate. I'm wondering if it's the switch that you're talking about in this thread?
There seem to be 2. I already ziptied the white one closed. Can I test the red one circled in yellow in the picture by taping the plunger closed? Or by removing it so the plunger doesn't make contact with the clutch pedal? The plunger on that switch is definatley "sticky" and doesn't go up and down freely.
Could this be my issue?
BoxsterInTheSun is online now   Reply With Quote
