Old 02-01-2025, 02:35 PM   #294
LoneWolfGal
LoneWolfGal's Avatar
You need to also understand that bore scoring is almost nonexistent on properly maintained 2.7L engines, and that it tends to be more pronounced on the later GDI engines rather than the port injected versions.
And Jack Raby says M96 engines in general are less susceptible to bore scoring, largely due to the use of cast pistons rather than forged. So let me ask you this — in view of those facts and given the engine I'm working on, would YOU remove the sump cover and scope out the bores? Unless you talk me out of it, I'm inclined to do it, because (1) the engine's out of the car, and (2) I'm trying to make it as bulletproof as I can.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
LoneWolfGal is offline   Reply With Quote
