Old 02-01-2025, 04:15 AM   #290
tcoradeschi
Registered Member
They have a lot of automotive uses; if you are faced with creating an opening in a metal panel, say a bulkhead, for a wire/cable or tube to pass thru something like a firewall or bulkhead, drills tend to "pull" on the metal, distorting it, which often requires going to a hammer and dolly to beat it flat so that a cable gland can seal it weather tight again. Rotary broach tools cut a flat, undistorted opening of whatever size is required in a single move, just run a deburring tool around the hole and install the cable gland and you are ready to make a weather tight pass thru with minimal time and efffort.
Dang. 2 days ago, I’d never heard of these, and now I gotta get me a set!
Conceptually not all that different from the holesaws I use in carpentry and much quicker than what we used back in the day, which were Greenlee knockout punches (drill a pilot hole, thread the two halves of the punch together thru the hole, and then pull the two halves together).
Tom Coradeschi
03 Boxster
tcoradeschi is online now   Reply With Quote
