Old 01-31-2025, 09:49 AM   #288
JFP in PA
They have a lot of automotive uses; if you are faced with creating an opening in a metal panel, say a bulkhead, for a wire/cable or tube to pass thru something like a firewall or bulkhead, drills tend to "pull" on the metal, distorting it, which often requires going to a hammer and dolly to beat it flat so that a cable gland can seal it weather tight again. Rotary broach tools cut a flat, undistorted opening of whatever size is required in a single move, just run a deburring tool around the hole and install the cable gland and you are ready to make a weather tight pass thru with minimal time and efffort.
