Old 01-30-2025, 01:01 PM   #283
Gilles
When I installed a BBI small crank pulley on my '07 987CS, I used a Dremel to file down the TDC marker to make room for the smaller diameter pulley, and I was very surprised how soft the block material was, as the Dremel bit grinded way the material very quick and easy.
In other words, go slowly so you don't grind more than you intend it..
Gilles is offline   Reply With Quote
