Old 01-27-2025, 05:06 AM   #1
DWBOX2000
Front right wheel liner
Hi, as posted in other posts; I need to find the cable to manually open trunk on 02 with electric frunk opener. Any tips on removing? Do I need to remove Phillips and torx screws at the bottom where liner meets the bumper? There is a plastic plug under the bumper that I don’t currently a tool to remove also.
I believe there are five plastic plugs and two plastic nuts.in the wheelwell that I’ve removed recently. Hopefully that’s all I need to remove.
Also, if the wire is where the factory left it, where is that?
Thanks.
DWBOX2000 is offline   Reply With Quote
