Old 01-26-2025, 01:36 PM   #10
gbp808
now zero fuel pressure
Well, I have moved from immobilizer to the basics, gas and spark, as you all suggested a month ago.
Zero pressure at fuel rail!
Relay INPUT(female side) checked:
85 (power TO relay) gets 3.6V with no key, and in position 1+2
86(ground) good
87(direct battery feed) : no voltage with any ignition key setting.
C4 fuse good.
bench test relay good
To my slow-turning logic, there are enough issues at the relay plug-in site that i shouldnt tear into the fuel pump side yet?
any thoughts on low voltage TO the relay and ZERO V where high current battery should be present?
thanks very much folks
garry
gbp808 is offline   Reply With Quote
