Old 01-24-2025, 08:09 PM   #6
elgyqc
elgyqc's Avatar
Originally Posted by LoneWolfGal View Post
Crank locked at TDC and bank 1 exhaust cam locked down. Well... the cam's almost locked down — a drill bit is holding the lock in place until I can obtain the appropriate bolt. Anyone happen to know the specs on the bolt I need?...
It is the same bolt that holds the pressure plate to the flywheel. Since you are not supposed to reuse these you should have some available.
Grant
elgyqc is offline   Reply With Quote
