Old 01-24-2025, 09:09 PM   #270
elgyqc
elgyqc's Avatar
Originally Posted by LoneWolfGal View Post
Crank locked at TDC and bank 1 exhaust cam locked down. Well... the cam's almost locked down — a drill bit is holding the lock in place until I can obtain the appropriate bolt. Anyone happen to know the specs on the bolt I need?...
It is the same bolt that holds the pressure plate to the flywheel. Since you are not supposed to reuse these you should have some available.
Grant
