Old 01-24-2025, 04:46 PM   #1
oldbadger
oldbadger's Avatar
Right turn signal
I suspect you have checked all this, but here goes.
Do you have the right bulb for the right front and have you tested the bulb for function? How easy is swapping the front and rear and testing the function? If you swap them and the front blinks rapidly you know that the bulb that doesn't light is dead.
Have you checked the fuse for the turn signals?
good luck
oldbadger is offline   Reply With Quote
