Old 01-22-2025, 04:12 AM   #1
Antoine86
Heavy Duty Scanner, Clearing Codes or Forced Regeneration
For heavy duty scanners, the following important factors and recommendations should be considered when clearing codes or performing a forced regeneration on heavy equipment and trucks:
Features Required for a High Performance Scanner
1. Reading and Clearing Codes:
– The scanner must support reading and clearing Active and Inactive DTCs (Diagnostic Trouble Codes) for various systems; engine, transmission, ABS, exhaust aftertreatment, etc.
2. Forced Regeneration:
– For vehicles with exhaust aftertreatment systems, it must support regeneration of the DPF (Diesel Particulate Filter).
– Some models also offer advanced regeneration features such as Monitoring smoke levels and Temperature control during the process.
3. Broad Compatibility:
– Ensures compatibility with major heavy vehicle manufacturers such as Cummins, Caterpillar, Detroit Diesel, Volvo, Mack, Paccar, etc.
4. Data Stream Monitoring:
– Real-time data monitoring to assess vehicle performance and diagnose issues during regeneration or other processes.
5. User-Friendly Interface:
– Easy-to-operate menus and clear instructions for beginners and professionals.
6. Upgradability:
– Regular updates to support new vehicle models and ECM software changes.
Recommended High Performance Scanners
1. NEXIQ Blue-Link Mini:
– Compact cordless device.
– Works with apps like JPRO Diagnostic and Nexiq eTechnician.
– Great for forced regeneration and code erasing.
2. Autel MaxiSys MS908CV:
– Comprehensive diagnostics for heavy duty and commercial vehicles.
– Supports forced regeneration, injector coding and other advanced features.
– Large touchscreen interface for easy operation.
3. JPRO Professional Diagnostic Tools:
– Known for extensive and in-depth diagnostics.
– Supports code clearing and forced regeneration for multiple makes and models.
– Real-time data and user-friendly software.
4. Launch X431 HD:
– Comprehensive truck and engine diagnostic coverage.
– DPF regeneration, parameter reset and more.
– A cost-effective choice with powerful features.
5. Caterpillar ET (Electronic Technician):
- Special tool for Caterpillar engines.
- Supports DPF regeneration, advanced parameter tuning and code diagnosis.
- Requires CAT Comm III adapter to connect.
Forced Regeneration by Scanner
1. Safety Precautions:
- Make sure the vehicle is parked in a safe open area to avoid heat hazards.
- Exhaust temperatures will be high during DPF regeneration so have a fire extinguisher ready.
2. Forced Regeneration Procedure:
- Connect the scanner to the vehicle's diagnostic port (usually 6 or 9 pin).
- Turn ignition key "ON" (engine off).
- Select DPF Regeneration from the scanner menu.
- Follow the on-screen instructions, including maintaining idle speed and other conditions.
- Monitor the operation to ensure it is completed successfully.
3. Clearing Codes:
- Once the regeneration is complete or repair work is complete, use the scanner to clear the stored codes.
Antoine86 is offline   Reply With Quote
