Old 01-21-2025, 12:14 PM   #255
LoneWolfGal
LoneWolfGal's Avatar
Originally Posted by pilot4fn View Post
Isn't the reason JFP mention for only driver side bank (2) cam to be locked on 5-chain engine because:
to change the IMSB you take only two chain tensioners out - 1 tensioner for the IMS - cam and 1 tensioner for the IMS - crank.
Risk to have the chain to skip a teeth is when there is no tension on the chain.
On the passenger side bank (1), the tensioner will remain in place under tension and the chain should not have a chance to skip there while you work on IMSB.
Actually, every knowledgeable source, including JFP, Jake Raby, and LN, recommends locking the exhaust cam on bank 1, the passenger side, on a 5-chain engine. Regarding tensioners, it's my understanding there are three, two timing chain tensioners and one IMS chain tensioner. LN recommends removing all three:
https://lnengineering.com/files/2023-IMSS-instructions-rev-03-24.pdf
JFP, care to weigh in?
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
LoneWolfGal is offline   Reply With Quote
