Old 01-19-2025, 06:27 PM   #244
LoneWolfGal
LoneWolfGal's Avatar
JFP would know for sure, but I'd think it's OK, since the cover is flat and the pressure is transferred to edges. The danger would be a single pressure point in the center.
I'd recommend a rubber mat of some sort. That diamond pattern steel can easily gouge or scratch the aluminum sump with even the slightest movement.
Al, I've been wondering when someone would comment about the diamond plate. Like you, I wasn't aware (until I touched it) that it's only a rubber mat with a diamond-plate pattern. Looks like the real McCoy.
The only structure in the center of the sump cover is the oil drain plug, but luckily it's recessed. Even if it projected, the "diamond plate" would probably compress enough to protect it.
Nevertheless, I'm prepared if JFP tosses cold water on the idea, in which case I'll have to come up with a blocking solution utilizing 2x4s and 1x2s.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
LoneWolfGal is offline   Reply With Quote
