Old 01-19-2025, 04:40 PM   #242
LoneWolfGal
LoneWolfGal's Avatar
Advice needed. Although it's still mostly supported by the hoist, the engine seems to sit solidly and securely on its large, thick aluminum sump cover. I had intended to put blocks under it, but it's not obvious how blocks should be placed. Can the sump cover support the weight of the engine without being damaged? If not, how are other folks approaching the problem? As I said, the hoist is supporting most of the engine's weight at this time.
BTW, you'll notice the bottom of the engine is dirtier than the rest of it, thanks to 39K miles of road grime. Gotta correct that state of affairs (along with the transmission) before I put it in the car. Clean engine, clean mind.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
LoneWolfGal is offline   Reply With Quote
