Old 01-18-2025, 03:33 PM   #2
LoneWolfGal
LoneWolfGal's Avatar
Originally Posted by DWBOX2000 View Post
I’ve done this 3 times. Not really that bad and I’m 54. Just have to slide in right. A short screw driver helps. Easier than removing front wheel liners.
I've done both, and difficulty- and PITA-wise I gotta give the nod to replacing the ignition switch. I have a set of the shortest screwdrivers in creation, but there's no room to turn the screw on the passenger side if you get the screwdriver seated. A small, L-shaped flat-blade screwdriver did the trick. Second choice: a screwdriver bit, turned with a small ratchet or wrench.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
LoneWolfGal is online now   Reply With Quote
