Old 01-17-2025, 02:02 PM   #6
Danimal
More than I'd like to admit! I also ordered bearings, axle nuts, and swaybar bushings. I'm preparing for battle! When a Porsche shop wants $300 an hour to do anything, I'd rather just replace it for a couple hundred bucks and not leave it up to chance. Plus everything will be apart anyway.
Originally Posted by BoxsterInTheSun View Post
Great questions. Let me try and answer them here...
I was going to rotate them front to back. I'm not toally sure what a staggered setup is, but thought it would be possible as the tires are currently the exact same size on the front and the back, just different models of tire. I could easily be missing something though.
In theory the shop that did the alignment and road force balancing was a pro tire shop, Wheelworks here in San Jose.
Date stamp is 17th week of 2021, so under 4 years old and visually in great shape. I haven't tried the 9/3, 12/6 test so will look into that.
Is this something that can be done visually? Or needs to be done by a tire shop?
Thanks so much for the update, I'll be eagerly waiting to hear your results, I had considered this as a potential fix also. How much is that job going to run you in parts?
Thanks again everyone for the help!
2001 Boxster S | Triple Black | Stock 17s | Bilstein PSS9s | BAD Shifter | 6x40w Cabrio Amp | 986.2 muffler
"Sixty percent of the time, it works every time!"
Danimal is online now   Reply With Quote
