Old 01-16-2025, 05:57 AM   #3
BoxsterInTheSun
Great questions. Let me try and answer them here...
Front to back. Vice-versa?
Likely you have a staggared setup... so that's not going to happen.
I was going to rotate them front to back. I'm not toally sure what a staggered setup is, but thought it would be possible as the tires are currently the exact same size on the front and the back, just different models of tire. I could easily be missing something though.
Me? I'm next taking it to a pro tire shop ) not a local independant (Joe's Tires) and having them perform a tire inspection.
In theory the shop that did the alignment and road force balancing was a pro tire shop, Wheelworks here in San Jose.
How old are your tires? How are your wheel bearings? Did you try the 9/3... 12/6 method?
Date stamp is 17th week of 2021, so under 4 years old and visually in great shape. I haven't tried the 9/3, 12/6 test so will look into that.
Originally Posted by azlvr View Post
Look for bent rims, that was my problem
Is this something that can be done visually? Or needs to be done by a tire shop?
Originally Posted by Danimal View Post
I’m in the same boat (think you may have seen my other post). Anyway I just ordered new control arms and tie rods front and rear. I figured if I have to do another alignment I’m going to do everything at once. I’ll let you know what I find. I’m pretty sure it’s my front lower control arms.
Thanks so much for the update, I'll be eagerly waiting to hear your results, I had considered this as a potential fix also. How much is that job going to run you in parts?
Thanks again everyone for the help!
BoxsterInTheSun is offline   Reply With Quote
