Old 01-13-2025, 12:20 PM   #5
elgyqc
elgyqc's Avatar
Originally Posted by LoneWolfGal View Post
Agree completely. I understand a few folks have gotten away with it without locking the cams, and I also read that 5-chain engines are less susceptible to jumping a tooth during the process, but I don't like taking chances. I borrowed LN's official toolkit, which includes the cam-locking widget. BTW, I read the tensioners can be simply loosened instead of removed. What's your thinking about that?
If I remember rightly the tension of the chains pulls the IMS off center making the reinstallation of the flange a challenge. If you are going to change the chain tensioner pads in the heads you have to remover the tensioners, so do the IMSB at the same time. By the way, in the PET they are called chain adjusters, which is handy to not confuse them with other parts that are tensioners... but I'm a minority of one who would like to adopt the Porsche nomenclature.
Grant
elgyqc is offline   Reply With Quote
