Old 01-11-2025, 04:10 PM   #221
LoneWolfGal
LoneWolfGal's Avatar
Boom. There are numerous events that can grenade an engine besides an IMSB failure. While The Solution may be a solid unit, the cost of the unit plus the cost to have it installed, because otherwise the warranty would be voided, is equal to or more than the cost of a replacement engine. And the engine could still blow up from other things, as you mentioned.
If "speed costs money" and someone wanted to go faster, they probably wouldn't buy a Boxster.
You have a point, Al. I'm certainly not going to fork over several thousand bucks to have a LN-approved shop install the Solution in order to qualify for the 5-year warranty. However, Jake Raby indicated that DIYers should nevertheless go through the registration procedure, including sending LN the old bearing. It will provide proof that the Solution has been installed. That's really all I care about, because it's unlikely the warranty would be needed anyway.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
LoneWolfGal is online now   Reply With Quote
