Old 01-11-2025, 02:41 PM   #220
piper6909
piper6909's Avatar
And to my knowledge, and what I have seen or heard from both LN and Jake Raby, none has ever failed in service. If fact, a some engines equipped with the Solution have suffered other types of failures (rod bolt failure, spun bearings, broken crank, dropped valve, etc.) and the Solution was removed from the failed engine, cleaned up, and installed in the replacement engine; something you cannot do with any other style of IMS retrofits.
Yes, they are more expensive, but "speed costs money; how fast do you want to go?"
Boom. There are numerous events that can grenade an engine besides an IMSB failure. While The Solution may be a solid unit, the cost of the unit plus the cost to have it installed, because otherwise the warranty would be voided, is equal to or more than the cost of a replacement engine. And the engine could still blow up from other things, as you mentioned.
If "speed costs money" and someone wanted to go faster, they probably wouldn't buy a Boxster.
2010 Subaru Forester
