Old 01-10-2025, 03:20 AM   #2
tcoradeschi
Registered Member
Your assumption that this is a wiring problem is likely a good one. I chased similar gremlins in a B5.5 Passat some years back. The culprit turned out to be a broken CANbus wire in the flexible bundle going to one of the rear doors. Took months, on and off. To find it, and about 10 minutes to effect a temp repair to it (solder and shrink tubing).
It’s tedious work, no question about it. Wiring diagrams in the Bentley aren’t totally awful, so use them as best you can.
Tom Coradeschi
03 Boxster
tcoradeschi is online now   Reply With Quote
