Old 01-08-2025, 04:28 AM   #2
Starter986
1998 Boxster Silver/Red
Originally Posted by kdh View Post
Thanks for the reply and the pics.
The problem with removing the two bolts from the other side is that I can't get my arm/hand up there and I'm not a big guy.
There is a steel bracket in the way - do some remove this?
I can't believe replacing a muffler could be so difficult. No wonder the mechanics charge so much.
I removed my muffler when preparing access for my mechanic to remove my transmission.
If that is a pic of the underside of your car... you've more **************** to remove so you can gain access to those nuts. Patience, patience, patience. Remove the traingle covver... everything that might be in the way of the muffler.
FWIW... that's what I execised because those two nuts can be a ********************. Good luck.
1998 Porsche Boxster
