Old 01-04-2025, 01:52 PM   #14
986andmx5
When I refreshed my suspension I replaced the sway bar end links and sway bar bushings as well. Looks like you already figured out to pick up the strut mounts, boots and bump stops.
The rubber grommets that attach the brake lines to the struts were disintegrating, so if you aren't replacing the brake lines, just be aware you may want to wrap them in that area so they don't chafe.
986andmx5 is online now   Reply With Quote
