Old 12-17-2024, 08:41 AM   #1
theiceman
Originally Posted by djw8282 View Post
Hello Spinnaker.
I'm trying to diagnose a startup problem after the car has been sitting for a while. Would the tach jumping just above zero constitute a functional crank position sensor? Thanks!
yes
CPS usually fail due to heat .. not starting after sitting depending if it is overnight or not , can either be cold start enrichment issue , or residual fuel pressure drop . depending on your particular scenario.
theiceman is offline   Reply With Quote
