					Originally Posted by  jakeru
				I went through this drill recently for the first time (a 2001 with the electronic hood release).  I didn’t encounter the alarm going off problem, but a folded up piece up paper behind the fuse box cover had instructions (from Porsche) on what to do if this happened.  I recall the instructions saying to insert your physical key into the driver’s door lock and rotating it to silence the alarm.  Then after silencing the alarm, operating the hood release switch.
Thanks! That worked perfectly on my 2001 Boxster S.  I had done this before, but did not have the alarm.  I had to put the key in the door after the alarm sounded and turn it counter clockwise. The alarm turned off, and then I was able to pop the frunk.
Pretty sure my voltage regulator died and took out my battery, which I found leaking battery acid. What a mess. Clean it up as best I could with a solution of baking soda. Ordering a voltage regulator.
