Old 12-15-2024, 11:22 AM   #39
djw8282
djw8282's Avatar
If the engine "fires" for a second when you use starting fluid but will not start under normal conditions. Then that tells you that there is a fuel delivery issue.
So you have to determine ,,,is the fuel pump bad? or simply not getting power?
Thanks for the reply blue62.
I have not. if you can detail the steps to troubleshoot in figuring out if the fuel pump is not getting power or a bad pump altogether I would appreciate it. I am pretty mechanically inclined but have not done any work pertaining to the fuel pump. Thanks!
djw8282 is offline   Reply With Quote
