Old 12-15-2024, 08:44 AM   #16
blue62
Originally Posted by djw8282 View Post
Hey blue62,
I know it's been a long time. I replaced the battery, fuel pump relay, and ignition relay which didn't fix it.
I just tried the starting fluid and it kicked on for a second then shut it down. I put some fresh gas and nothing. I did hear a stretch from the starter. Any suggestions?
If the engine "fires" for a second when you use starting fluid but will not start under normal conditions. Then that tells you that there is a fuel delivery issue.
So you have to determine ,,,is the fuel pump bad? or simply not getting power?
