!!! Update!!!
Rolling downhill and engine off. No vibration when turning.
Rolling downhill with engine idling. Little bit of Vibration.
When I raise the RPMs I get vibration when turning left.
So at this point I’m now thinking something is either loose (a bolt) or the transmission mounts need to be replaced.
I’m going to re check torques for all of the bolts between transmission and motor first.
Then check the mounting bolts.
Bummed I spent a lot of time getting to this point but that advice was amazingly useful.
Thank you @Gilles!
