Old 12-13-2024, 02:12 PM   #191
Newsguy
LoneWolfGal, I think you misunderstand the Solution.
It is a plain bearing as those on your crankshaft, so it certainly needs an oil feed!
Any other replacement is still on the clock, and will need to be replaced periodically. I think LN even says this in the description.
The "Solution" is supposed to be a permanent fix, which is obviously cheaper if you keep the car for a long time.
I have purchased one, but my plan is to use the ball bearing version on the one I'm rebuilding now, and using the Solution for the next one which gets the Nickies treatment.
-H. L. Mencken
