Vibration turning left, not right
1999 Boxster. Just replaced the engine from EBay. Never would have guessed but it’s running great. Now that it can be driven there is a heavy vibration when turning the wheel left but smooth as butter turning right.
To put a finer point on it:
I believe this is a vibration from the front end. So I replaced all 4 tires, both front wheel bearings, upper and lower tie rods, coffins support and fork.
The vibration did not go away!
The only thing left I could change is the actual hydraulic steering mechanism and the anti-roll bush’s. And have brakes resurfaced in case they are warped.
So what is the vibration?
No vibration sitting still regardless of RPM.
Some vibration when going slow.
Going straight there is minor vibration.
The ever so slightest turn of the wheel right and it all goes smooth as butter.
Turn further left and you can find a point of resonance where everything shakes, even your seat.
Further left and it calms back down but is still present.
I have noticed that the steering wheel is turned a bit to the right to go “straight” but I think that is mostly due to my crude install of the tie rods.
So here is my plan:
1. Front brake rotors are getting reconditioned tomorrow (Friday) though I think they look almost new. Did seem to drag a little through part of a rotation.
2. I am going to loosen all the suspension parts I installed and re tighten them under load (did not do it previously. Tightened them in the lift. And bc I replaced the engine the super long rear forks were removed too)
3. Then I’m going to get the alignment done
Then I will pray and go for a test drive….
After that I’m not sure what else to troubleshoot or try and in what order.
Could it be the back end transmission motor mounts? (Front motor mount is new)
Could it be something else?
All suggestions welcome!
Erik
1999 Boxster Base
67k mi chassis
101k on the engine
Texas
