Old 12-07-2024, 01:44 PM   #2
piper6909
piper6909's Avatar
The engine was a match for what was in the car, including ALL UPDATED PARTS SINCE THE CAR WAS FIRST ASSEMBLED, which is pretty much the way they have always done things. After getting stung with a class action over the single row bearings, they switched the the oversized non serviceable unit, which was an updated part. Any other updated parts were also replaced, but otherwise the AT engine was a match for the original one.
Sorry, I don't mean to split hairs with you but an engine with "updated parts" is not "an engine that matches what the car originally came with." I would imagine that the engine block's casting or milling has to be different in order for the oversized bearing to fit. So, no, it doesn't match what the car came with.
I only mentioned it so if the OP someday decides to service the IMSB they will know NOT to rely on what the car originally came with, as I did.
2010 Subaru Forester
