Old 12-05-2024, 05:58 PM   #2
BoxsterInTheSun
You want to get a new one..! as the original will be all brittle and will crack just by looking at it..
PS: You don't need to remove the intake plenum, if you remove the cover behind the seat, with a bit of patience, you can plug it into the connector.
Great to know, thank you! Is it the part number I referenced above? I'm finding conflicting info...I have a 2002 986 base model.
Thanks again!
BoxsterInTheSun is offline   Reply With Quote
