Old 12-04-2024, 03:12 PM   #1
spinjockey
This sounds like a problem with the variocam system. The variocam system is active above 1500 rpm. You need to check the cam deviation angles and fuel trims to tell if this is chain stretch or more likely cam pad wear. You really shouldn’t drive the car until you get it properly diagnosed because if it is a problem with the variocam system you do not want the chains to jump time.
spinjockey is online now   Reply With Quote
